Meshlights on dupliframe error
  • Meshlights on dupliframe error
    Latest Vray for Blender build, vrayblender35-2.79-a378f2b-x86_64-windows.zip
    Error in system console:
    Error in file "C:\tmp\vrayblender_standalone\scene_nodes.vrs cene ", line 19: Token ")" not recognized as valid token
    scene_nodes.vrscene-file, few lines from line 17:
    Code:
    Instancer2 Instancer2@Node@OBCube {
        instances=List(1.0000,
            List(0, TransformHex("00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000"), TransformHex("00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000"),),
            List(0,
    Blend file: http://pasteall.org/blend/index.php?id=50822 Click image for larger version  Name:	e697560510.png Views:	1 Size:	65.6 KB ID:	1019281
    Win7 Ultimate 64bit, GTX 970, Standalone version: V-Ray Next 4.30.03,
    I see it works in an older build. I'm not sure if it should be working - when you have an object tree, you usually can't share it for multiple objects. At least I've run into problems with things like meshlights and proxy objects.
      Latest build, same error also Lamps dupli frames/verts/faces
        Thanks Poseidon, dupliframes now works if there is only one dupliframe object, like lamp parented to curve and setting curve duplication to dupliframes. Adding second curve and duplication to dupliframes and another lamp etc. then only one dupliframes are rendered.
          I pushed a fix for multiple objects instanced with one dupli frame. But can you please upload a scene you are testing with?
            Blend file
              JuhaW Pushed fix for the scene, test with next nightly and write if there is a problem still.
                They work now, thank you.
