Color Correct node
  • Color Correct node
    I'm hoping this is just user error . . .
    On re-rendering an older file recently the image texture plugged into the color correct node seems to be ignored.
    Here's what it rendered before, and now with the texture ignored.
    I changed the light from hdr to area to reduce the file size - https://www.filehosting.org/file/det...olorCorrect.7z
    I am using a (relatively) recent nightly build of vray 3.6, not Next, on Ubuntu 18.04. The image file should be packed in with the .blend.
    organic If you change Col Offset to black (0) does it fix the problem for you?
      Yes, I think it does.
      Sorry for being a bit dim, and thanks
