Emitters+empties+proxys
  • #31
    Re: Emitters+empties+proxys
    voytov, try smth from this list:
    - apply scale to all objects
    - set start=0 end=1 lifetime=1 (to avoid unborn particles)
    - I also get an issues of 90deg rotated particles after export so I reset rotation on particle and rotate its mesh (don't know where it came from - may be from this particles changes)
    After all of this "Building static raycast accelerator" goes fine.
    andrei.izrantcev@chaos.com
    Support Request
    • #32
      Thanks Andrey. It helped a lot. It is crucial indeed, to rotate y-90 deg the mesh not the whole particle object.
      But..
      One more issue arose:
      If i connect a vrmesh that was created in a vertical manner (not rotated y-90 before generating - wchich applies to externally acquired vrmesh'es) it will render as "lying" (e.g. a tree) even if I y-rotate the vrmesh containing object that becomes a source for emitter...
