Error with specific blend scene, can't render anymore.
  • Error with specific blend scene, can't render anymore.
    Hi, I was working with a scene with no problems but for some reason I can't render nothing from this file anymore. Even appending does not work. (for materials work but not for objects)
    Here iis error log: http://www.pasteall.org/17127
    Any tip?
    architect at oona
    Re: Error with specific blend scene, can't render anymore.
    what Blender do You use?
    if You are using vb 2.53 update to 2.55 build, then if still nothing udate the script to the newest one.
    mat tests>
    render tests>
      Problem solved! It was a problem with a missing linked blendfile.
      Now it's rendering fine!
      I'm having some troubles when using more than one proxy files. All proxies in the scene render the same vrmesh insted of the linked one.
      architect at oona
        cyberlecs, in 2.5? Can you show this scene? I just try about 5 different and it does fine.
        Btw, cool render!
        andrei.izrantcev@chaos.com
        Support Request
          hello
          can u share how create proxy step by step ?
            .. So you have vb_proxy.exe copied to a folder: \2.56\scripts\io\vb25 (at leas in windows)
            Then:
            - create a mesh object, unwrap uv maps, apply materials to the desired groups of faces
            - in Blender top menu bar chose rendering engine : "v-ray" instead of "blender render"
            - select the desired object (one at a time)
            - go to: "Object Data", at the bottom fill the "Path" info to point to the folder you want to store newly created proxy .vrmesh files in
            - fill "Name" for proxy file name
            - press "Create proxy"
            - observe Blender console window to get info on progress while generating massive files...
            ..if nothing happens that may mean vb_proxy.exe was not found.
              hi voytov and thank u , it work fine now but the problem in array modifier
                seghier, array will not duplicate proxies. Use particles or dupli.
                Support Request
