animation render with array modifier
  • animation render with array modifier
    Hello, is there a bug or is it my fault:
    I want to make a animation where an Object has an Array modifier. on this modifier a offset value should change while animation. When i hit render ( with animation pipeline enabled)
    vray renders the same position of the array over and over again.
    The same Problem i have with shape keys. it seems that the exporter is exporting only one mesh (could it be?)
    So is there a special setting or do i have to use the Blender 2.49 for animations at the moment?
    Re: animation render with array modifier
    snfx, array and things like shapekeys are changing mesh - so you should enable Animation, then press Export meshes (this will export all frames mesh data) and then Render (this will export mat, tex, object transforms etc..).
    andrei.izrantcev@chaos.com
    Support Request
      first, thanx for the fast reply, grazy how fast you answer but ive tried this and there was no effect....
      i have just downloaded a fresh build (9th february), do i need the vb_proxycreation?....thank you for your help...
      greetings snfx
        snfx, send me your scene I'll check if its a bug.
        Support Request
          Ok here is a simple testfile, ive just downloaded the latest blender build with vray using your link and i have vray standalone win x64 (maya 2011), with tongle....
          maybe it is really just a little mistake of mine....hopefully
            snfx, ops some test code leaks into release build ((( Ok, I'll try to update builds as soon as possible.
            Support Request
              you are the greatest
                I think it's something not right with the script, rather than the builds. It doesn't work properly on my builds with the latest script either. It is as described. The animation will play in blender, but when rendered shows only the current frame (the one active when "export" was pushed). It's the same result if "count" is keyframed, or I imagine any other variable in that modifier; whatever is present when export is pushed is rendered over the animated frames. It's also the same with other modifiers like solidify, screw, etc.
                Cory
                Cory Petkovsek
                Corporate Video
                  tinmanjuggernaut, its a build problem - http://github.com/bdancer/vb25-patch/co ... 2250c11fa4 (VB_TAGGED stuff)
                  Support Request
                    Yup, works now.
                    Cory
                    Cory Petkovsek
                    Corporate Video
                      Hi, you guys are really fast...i have tried to download the vb25 folder and replace it in blender scripts/io/...doesnt work,
                      sorry, i am a beginner in this: is there a hack to install this stuff or do i have to wait for a new build?
                      greetings snfx
                        snfx, Cory has his own build compiled from source. I'll update build tomorrow.
                        Support Request
                          cool, thanx
