Exporting for animation takes ages!
  • Exporting for animation takes ages!
    Hi there,
    i would like to know if it is normal, that it is taking ages to "export meshes" for animation , for 250 frames took about an hour or almost 2h! its an quite simple scene
    [attachment=0:yxfcamhh]Untitled-1.jpg[/attachment:yxfcamhh]
    when the export of the mesh is done, I press the render "animation" button, than it runs the animation in the viewport, and than again its is taking ages, or nothing happens from times to times
    is it a problem of my settings or is it like this?
    [attachment=1:yxfcamhh]Untitled-2.jpg[/attachment:yxfcamhh]
    i'm using the "official" build win 32 of bdancer of his page. i'm using win 7 with a 8 core and an quadrofx 5500
    i hope that i'm doing something wrong, because i really would like to use blender with vray and not maya ! exporting the animation as FBX importing in maya, than set up the materials and so on just sucks
    all the best,
    piripi
    Re: Exporting for animation takes ages!
    ok i found something interesting
    is it possible to set up with blender sofar?
    http://www.spot3d.com/vray/help/150SP1/ ... s_anim.htm
    but anyway, it also mentions if it is a simple scene, i could render it straight...
      is VRaySphereFade already integrated?
        hi there,
        is it possible that the IR (rendering" for animation does not work? i generated a prepass, and than turn over to "animation (rendering)" and chosed the first file, but than it does not render?
        what am i doiong wrong? the vray renderscreen just stays black...
          Look in the console for errors. This will help to fix the problem.
          May be you will have to delete frame number from chosen file name.
          Not yet.
          Depends on the scene.
          Most of my "heavy" scenes takes about 15-30 sec per frame to export.
          You could send me your scene by email for investigation.
          andrei.izrantcev@chaos.com
          Support Request
            hi there,
            has anybody experience with the irradiance maps "animation-prepass" and "animation-rendering" for animation? in maya i could make it work.
            blender just makes the prepass, but when i select " animation rendering" and choose the first file of the prepass ir file, it will just render the first frame and the rendering is totally black...
            is it a global problem or just my setup?
            i also tried a simple scene with a plane an 1 cube, basic matte materials, no success
            all the best
            philipp
            here a single frame, hope i can make the animation soon
            [attachment=0:mxqwgqyo]0_01_test.jpg[/attachment:mxqwgqyo]
              Try removing frame number from the file name after selecting file.
              Support Request
                hurra, this is it! now it is rendering just fine!
                thanks alot!
