render channels not showing
  • render channels not showing
    hi
    start a new scene, select the cube go to render channels, add one and select any option from the list, it won't show the object properties just a line and this error in console:
    Code:
    Traceback (most recent call last):
      File "C:\blender\win64-trunk\2.57\scripts\startup\vb25\ui\properties_render.py
    ", line 982, in draw
        render_channel.name= get_unique_name()
    AttributeError: Writing to ID classes in this context is not allowed: Scene, Sce
    ne datablock, error setting VRayRenderChannel.name
    Re: render channels not showing
    Damn they even restrict it here...
    Use custom build - its allowed there and will work fine.
    andrei.izrantcev@chaos.com
    Support Request
      not my fault, thanks for the answer, waiting for a solution
        The solution is use my builds - http://github.com/bdancer/vb25/downloads
        Support Request
          thanks but i can't, as i'm making a graphicall builds for the masses with many patches and render engines, and i'm trying to integrate everything as much as i can, and rendering engines comes @ 1st in my list, so i'll be waiting for either one of those:
          1-modifying your patch so disabling the render window only when using vray as renderer.
          2-modifying you exporter to it could work around the latest updates to the API.
          although i like the 1st one more as i'm dying to add your patch to the list of my patches
          anyway i'm still supplying your exporter with my builds.
          thanks
            You don't need a patch for this: Select Blender internal -> go to render panel -> select Display = Keep UI -> save settings -> done =)
            Support Request
              thanks man for clearing that but your patch now wont compile with the latest trunk
              here is the error message:
              Code:
              crazyspace.c
              source\blender\editors\space_api\spacetypes.c(67) : fatal error C1083: Cannot op
              en include file: 'exporter_ops.h': No such file or directory
              Compiling ==> 'editmode_undo.c'
              Csompiling ==> 'ed_util.c'
              cons: *** [Z:\Development\blender\build\win64-temp\source\blender\editors\space_
              api\spacetypes.obj] Error 2
              editmode_undo.c
              ed_util.c
              scons: building terminated because of errors.
              i compiled with scons & msvcsp1 and a clean blender SVN.
                Please, check patch wiki page: http://github.com/bdancer/vb25-patch/wiki
                Support Request
                  ok it compiled i forgot to copy the export folder to source\blender
                  thanks man
