dongel ?
  • dongel ?
    Ive got a dongle for evaluation . and I have installed the drivers for 64 windows. I cant make it work. The control panel says this...
    I have read Bdancer and chaos group instructions.
    1.10 2:28:44:610: Logon received from "wibuke64" at Tony-PC.
    11.10 2:28:44:610: Connected as L00016, no slot allocated.
    11.10 2:37:08:110: Connection L00016 ("wibuke64" at Tony-PC) closed.
    I have vray for maya demo and it works fine.
    I still get max resolution supported 600x450
    i also see this...
    11.10 2:09:07:304: Rereading all WibuBox entries
    1 port scanned: 0 WibuBoxes at 0 ports found.
    Table of supported clusters:
    - No cluster table exists.
    It says 0 boxes found . I see the dongle in control pannel.
    #1 Vray will work offline?
    # 2 what do I do now?
    I d o not have... under programs/ chaos group/Licensing > Launch VRay license server
    Re: dongel ?
    It's not clear to me if you have complete installation of all V-Ray system elements now...
    -have you executed the licence 2 dongle transfer procedure? (they should send you instructions for that at the time of granting the evaluation licence)
    -You really should have that "Launch VRay license server" element in "chaos group". Have you executed "vrlservice_adv_22001_x64.exe" (or similar installer)?
    -To clear things out I'd uninstall that V-Ray for maya DEMO and execute "vray_adv_20004_maya2012_x64.exe" (I guess that's the current engine installer).
      Re: dongel ?
      Thanks I think you are correct . ill get support form the site Monday.
      Thanks
