Vray Output Filename Variables
  • Vray Output Filename Variables
    Quick question. Are there besides the %C camera variable other elements you can incorporate in the filename, or even just have vray output it with a incrementing number each time you render an output?
    Would be handy for preview images, so you don't have to change the filename output each time if you don't want to overwrite the previous rendered image.
    thx!
    Re: Vray Output Filename Variables
    This could be implemented, but will be in the bottom of my TODO.
    Try changing frame and you will get different filename.
    andrei.izrantcev@chaos.com
    Support Request
