win-64
First of all let me thank you for your great work, I am a new user to vray, so bear with me please. I have found this issue happens to me on both your custom build 43368 and using the script with build number 43660 I will try a newer build tonite and update if it fixes the issue. I have exhausted searching for this issue here and on the net so im here. I hope its just me and my settings and I have have a box ticked thats causing the problem, When I run the the render for some crazy reason the script calls the vray exe twice. I am not using animation and cannot find a setting for some type of batch rendering. When I render the windows task manager goes from 0 to 2 instances of vray running. I do not have vray installed in 2 places. I am using the 2.0 version of the demo standalone, the blender console also shows the addon calling the exe twice. Everything renders fine I just get 2 frame buffers and 2 renders of the same scene. However, on some of my renders this does not happen, this leads me to believe that my ignorance not your awesome addon is the root of my issues. thx in advance Iron
