Vray blend material
  • Vray blend material
    Is there a way to create a vray blend material in Vray blender, and if not, is this something we can expect in the future?
    Thank you
    Re: Vray blend material
    Use nodes to mix materials - currently this is only way.
    andrei.izrantcev@chaos.com
    Support Request
      Hi bdancer,
      I was trying to do the same, but nodes don't render with me in vray (they rendered fine in blender internal, so there was no problem with the setup). Is there something special you have to take in mind for vray?
      thanks,
      wim
        May be they are broken if there were some api changes, but generally exporter currently supports the following nodes: material, texture, mix and invert.
        Support Request
          I find they have some quirks about where the textures/materials are property of.
            Thank you for the quick replies.
            I will try some more things and report back if i get some better results.
