Bus error: 10 while exporting meshes
  • Bus error: 10 while exporting meshes
    I'm on OSX 10.7.3, Blender VRay 2.61.4, VRay Standalone 1.5.01, VRay Core version 2.00.01.
    I can't render my scene, because when it exports the meshes, Blender crashes and I have this error message: bus error: 10. All seems fine when I started working on the scene, but I have added multiple instances of grass and leaves, since then, it crashes. I tried to enable Instances in the Exporter panel but it still crashes. Thanks for the help.
    http://www.bupla.com
    Re: Bus error: 10 while exporting meshes
    Could you share that scene?
    andrei.izrantcev@chaos.com
    Support Request
      Of course, just press render and you should see the crash.
      There's a text object, I don't know if the font is embedded. I tried both with the text object and text converted to a mesh but it still crashes. Thanks.
      The file is downloadable here: http://www.bupla.com/scene.zip
        Thanks!
        Will be fixed in next build update. The problem was that C-exporter tries to export hair particles as hair when it was used to distribute objects.
        By now disable particle system on object on layer 20 (solPart - Herbe) or enable "Active layers" for mesh export, this will help to render this scene.
        Support Request
          Brilliant, everything is fine now, thanks a lot!
