Hi Andrey,
When I use image sampler type: Adaptive DMC
and have checked Use DMC sampler tresh,
then tweaking Noise threshold and Adaptive amount doesn't give any change in the preview (show samples mode). The samplig density areas are all round the same in any variant.
If I deactivate Use DMC sampler tresh. and play with Color threshold only I can see the proper changes according to its value modifications... But with Use DMC sampler tresh - it acts as if it was "secretly" using "Color threshold"!
If I understand it right, tweaking Noise threshold and Adaptive amount should give observable changes in color preview mode...
Am I right?
It's on VB 43742 custom build with latest script
V-Ray build Dec 11 2011
Am I right?
