Rendering Animation
  • #16
    Re: Rendering Animation
    Ok guys... We tested in depth the problem. The results are:
    - Python correctly closes the vrscene files, BUT if I try to delete the scene file windows alerts me that someone is using these files and blocks my deletion. When I close blender the file is released and it can be deleted. So when vray try to open this file (when blender is on and the render script is running) it gets the same error.
    - If I open the same scene files with c/c++ program written by me and at the same time I start vray from shell, vray returns the same error.
    - If I open the same scene files with c/c++ program written by me while the python render script is running, I get NO errors from my program.
    - If the render script closes itself before vray trying to read the scene files, the renders start without problem, obviously all vray renders work on the last frame exported by the script (in this case I delete the process waiting).
    I've checked that python closed correctly the files trying to write something in the files after closing them, and of course python tells me that it is not able to write on closed files.
    I can't understand if it's a problem of python or windows.
    • #17
      Great thanks for your efforts!
      As I have no real coding skills, I'm sorry not being able to help.
      Hope the things will clear out.
      One question: I haven't worked on linux version of V2B for some time. Is this (or similar) problem happening there too?
      • #18
        Good question, i think Andrey works on Linux (i'm not sure), if he have the time to testing this, we'll know if the problem come to Windows...
        Infographiste 3D freelance - http://www.arnaud-travert.com/
        • #19
          Ok, after a night without sleep I found two solutions.
          I try the first changing the python scripts, but the work is to wide and error prone. Now I try the second way building an external program that fix the problem during the vray render.
          However the problem is that python works in high level and when closes the files it's not sure that files are closed also at low level. As soon as possible I will post the results and the program
          • #20
            YEAH! Bug fixed!
            And without build an external program. Currently I'm checking if it's all right with other things like texture, lights etc...
            • #21
              Hello,
              i made a very simple test, in my scene i have only a cube and a sphere and they parented to an Empty.
              This is the Empty that i have animated on 40 frames.
              And here the error :
              In Full Range :
              In Frame-by-frame :
              There is my blend : http://www.pasteall.org/blend/16511
              PS : I'm using Custom Build "46731" for windows 7 64 bits, and my exporter is updated.
              • #22
                Try my fix some post before.
                • #23
                  Hello Worufu,
                  Thanks for your fix on render.py, but it doesn't works :
                  • #24
                    Doh! Another bug with the read permission
                    • #25
                      Snif... Anybody have a solution ? Andrey maybe
                      • #26
                        Spent a night on this - still no solution ((
                        andrei.izrantcev@chaos.com
                        Support Request
                        • #27
                          Fixed again after it was fixed a few updates before and then broken again =) Thanks to ArnaudT for finding some working version; problem was that files were initialized twice.
                          Support Request
                          • #28
                            Lol, good work!
                            • #29
                              Hi, I have set up a particle animation scene with some explode and other modifiers. It's simple destruction.
                              When i render a test image from the scene the render is perfect.
                              But when i'm starting the animation is rendering the sequences the particle system is disappearing.
                              Can help me somebody why it's happening this effect?
                              The image below is representing the problem.
                              • #30
                                OK! The problem was solved.
                                Just turn on "Rendered" display particles on the particle panel.
