Irradiance Map: Incremental add to current map not working.
  • Irradiance Map: Incremental add to current map not working.
    Hello there.
    I want to render a scene from slightly different angles. I would like to reuse the Irradiance map for that, that's what the "incremental add to current map" mode is for, I should be able to save the map to disk and then re-use it, but I can't. It doesn't seem to work at all, it is saving the vrmap file correctly, but it isn't re-using it. I think it only works for animations currently (and camera loops?) as I couldn't even find a way to configure the file to look for irmaps. Maybe it is supposed to use the file specified in "Auto Save", but doesn't work.
