Vray multibake textures
  • Vray multibake textures
    Hi all,
    Me and my friend are trying to find a way to bake multiple texture with vray in blender,
    after some help we use this script:
    Code:
    import bpy
    sce = bpy.context.scene
    # Enable autosave
    sce.vray.exporter.auto_save_render = True
    sce.vray.SettingsOutput.img_dir = "//bake/"
    # Enable Bake
    sce.vray.VRayBake.use = True
    # Manual object list:
    ob = ['cube','plane']
    # for ob in objects:
    # Selection
    for ob in bpy.context.selected_objects:
        sce.vray.VRayBake.bake_node = ob.name
        sce.vray.SettingsOutput.img_file = "bake_%s"%(ob.name)
        bpy.ops.vray.render()
    the problem is vray opens 2 windows to bake, but renders 2 times only the 1st object (cube).
    it's possible to fix?
    thank you in advance!
    Re: Vray multibake textures
    Set
    Code:
    sce.vray.exporter.wait = True
    and it will wait until render end.
    So it'll be like:
    Code:
    import bpy
    # Enable autosave
    # Enable Bake
    # Wait until render end
    # Selection
    # Restore settings
    sce.vray.VRayBake.use  = False
    sce.vray.exporter.wait = False
    andrei.izrantcev@chaos.com
    Support Request
      thank you alot!
      that's works but still not perfect because it start to render but when finished to start the new bake needs i close manually the vray frame buffer.
      how can tell vray to close the process and start with other automatically?
      thanks in advance!
        Code:
        sce.vray.exporter.autoclose = True
        Support Request
          Thank you very much bdancer, you solved our problem
          i really appreciated your help, your exporter is just awesome!
          if i can i would ask you another hint about the baking textures with vray,
          atm the only way to bake textures with vray is on individual objects, my question is:
          would be possible bake by materials and not by objects?
          for example a room with many materials multi bake by materials?
          thanks
            I guess may be you could just collect objects by materials, not sure if its possible to bake just material.
            Here is an example with UI and operator stuff http://www.pasteall.org/40352/python you will just need to add some of the baking code.
            Support Request
              Hi bdancer thank you alot for your help!
              The first solution about bake objects works perfectl!
              Unfortunatly we are not scripters so the one for materials we tried to complete the script u provided in pasteall.org but neither start the rendering, so please could you write the script with also the bake part?
              Thank you again for your work
                http://www.pasteall.org/40363/python
                After run there will be a panel in Scene buttons called "Bake Tools" you'll find all stuff there.
                Have fun! =)
                Support Request
                  I really liked the "bake by selection" script. I filled in the gaps and use the version below.
                  However, this locks Blender until the renderings are finished. I could use two instances of Blender to keep working, but is there a way to get around this?
                  Code:
                  import bpy
                  # Enable autosave
                  # Enable Bake
                  # Autoclose
                  # Selection
                  # Restore settings
                  sce.vray.exporter.autoclose = False
