V-Ray/Blender Installation Ubuntu 12.04
  • V-Ray/Blender Installation Ubuntu 12.04
    Hi!
    I am trying to get V-ray and Blender working in Ubuntu 12.04.
    I used Blender 2.67b. Copied and renamed the vb25 and put in the /sripts/startup folder.
    Also installed vray-demo-22001-maya2011-linux-x64 and the maya2012 version, both don't seem to work
    I haven't tried to set the path to the vray executable manually, since I am not shure which file that is.
    I have tried to make a system link to the usr/bin/ according to the FAQ (Errors)
    In the Terminal i get this message:
    Code:
    V-Ray/Blender: Creating directory "/tmp/vrayblender_paul"... done
    V-Ray/Blender: Writing scene...
    V-Ray/Blender: Writing meshes...
    V-Ray/Blender: Writing meshes... done [0.00]
    V-Ray/Blender: Writing frame 1...
    Traceback (most recent call last):
      File "/home/paul/Documents/blender-build/blender-2.67b-linux-glibc211-x86_64/2.67/scripts/startup/vb25/render_ops.py", line 1018, in render
        err = vb25.render.render(self, scene)
      File "/home/paul/Documents/blender-build/blender-2.67b-linux-glibc211-x86_64/2.67/scripts/startup/vb25/render.py", line 2054, in render
        export_and_run(init_bus(engine, scene))
      File "/home/paul/Documents/blender-build/blender-2.67b-linux-glibc211-x86_64/2.67/scripts/startup/vb25/render.py", line 1947, in export_and_run
        err = write_scene(bus)
      File "/home/paul/Documents/blender-build/blender-2.67b-linux-glibc211-x86_64/2.67/scripts/startup/vb25/render.py", line 1653, in write_scene
        write_frame(bus)
      File "/home/paul/Documents/blender-build/blender-2.67b-linux-glibc211-x86_64/2.67/scripts/startup/vb25/render.py", line 1613, in write_frame
        _write_object(bus)
      File "/home/paul/Documents/blender-build/blender-2.67b-linux-glibc211-x86_64/2.67/scripts/startup/vb25/render.py", line 1377, in _write_object
        write_object(bus)
      File "/home/paul/Documents/blender-build/blender-2.67b-linux-glibc211-x86_64/2.67/scripts/startup/vb25/render.py", line 1183, in write_object
        write_materials(bus)
      File "/home/paul/Documents/blender-build/blender-2.67b-linux-glibc211-x86_64/2.67/scripts/startup/vb25/render.py", line 864, in write_materials
        mtls_list.append(write_material(bus))
      File "/home/paul/Documents/blender-build/blender-2.67b-linux-glibc211-x86_64/2.67/scripts/startup/vb25/render.py", line 700, in write_material
        write_material_textures(bus)
      File "/home/paul/Documents/blender-build/blender-2.67b-linux-glibc211-x86_64/2.67/scripts/startup/vb25/texture.py", line 536, in write_material_textures
        mapped_params= PLUGINS['BRDF'][VRayMaterial.type].mapto(bus)
      File "/home/paul/Documents/blender-build/blender-2.67b-linux-glibc211-x86_64/2.67/scripts/startup/vb25/plugins/BRDFVRayMtl.py", line 641, in mapto
        BRDFVRayMtl=  BRDFLayered.BRDFVRayMtl if BRDFLayered else VRayMaterial.BRDFVRayMtl
    AttributeError: 'VRayMaterial' object has no attribute 'BRDFVRayMtl'
    I am very thankful for any hints/tipps and sorry for this noobish post!
    Regards,
    Paul
    Re: V-Ray/Blender Installation Ubuntu 12.04
    Hi! It's not noobish at all, here viewtopic.php?f=8&t=1202 is the same error... very strange, I'll check this.
    Could you try project's custom build from here? http://cgdo.ru/vrayblender
    andrei.izrantcev@chaos.com
    Support Request
      Amazing! It worked with the custom built. You are a hero!
      Thanks a lot!
