Hi everyone
I'm having problems rendering caustics. I have a simple object with the glass preset material applied to it. When I check the caustics in the render tab, the object just creates a shadow of the object, when I uncheck it, I do seem to get a caustic, but I can't control it. When I change the settings in the wrapper, both for the object recieving as for the one generating, It has no effect. When I check caustics and change the caustic samples of my sun from 1000 to 20000, the calculation takes much longer, but I see no change. When I look at the caustics render channel, it's completely black.
The first image is with caustics turned on, the second with caustics turned off. I was expecting it to work the other way around.
What am I doing wrong?
Thanks in advance for all help and ideas!
