Can't get VrayBlender to render after new installation
  • Can't get VrayBlender to render after new installation
    Am I missing something?
    Everything was running fine untill I reinstall Windows 7x64 OS. Now I just can't get VrayBlender to render. For install VrayBlender I use the same files as before Windows reinstalation("vrayblender-2.67-57238-windows-x86_64" and "vray_demo_22001_maya2012_x64"). If I hit F12 the Task Manager just shortly shows vray.exe in Processes, but nothing happens at all, no VFB, no render.
    Any Idea?
    Re: Can't get VrayBlender to render after new installation
    https://github.com/bdancer/vb25/wiki...)#wiki-General
    andrei.izrantcev@chaos.com
    Support Request
      Thank you for the link, getting nearer. I've checked Window -> Toggle System Console. Although I do not understand much what it says, on the end there stays 1 error:
      Could not obtain a license (4096). I also tried older release of vray - the same error.
      Do I need license if I want to run just the demo version of vray?
        Have you got the demo from the official site at chaosgroup.com?
        Support Request
          Yes
            I'll try to check what goes wrong. This demo should work fine..
            Support Request
              Ok, thank you for your quick posts and attention.
                Yep, looks like their demo builds become a little outdated; you could try setting year to 2012 or use this trick (hope it still works).
                Support Request
                  Problem solved, that little trick do the job...
                  Thank you, great job.
                    New demo builds are uploaded on ChaosGroup site.
                    Support Request
                      Thanks for good news..
                      Although that trick above solved my problem, it changes date of windows OS and it causes problem with internet connection and programs like Thunderbird for example.
                      With the new demo builds everything ok.
                        i have this problem
                        after update exporter for changing uv chanel of bake
                        my vray blender dont work
                        and send me this error
                        after isee this error i change vraystandalon 2.0.0.4 to vray 2.3*
                        and again see this error
                        [attachment=0:asa53vhy]Untitled-1.gif[/attachment:asa53vhy]
                        i am sorry i just setup vraystandalon after setupvraystandalone and vray for maya problem has been end
                        coooooool thank you mr Izrantsev
                        if have free time to learning blenderscript i help you
                        you realy diligente man
                        I am Programmer,I have no life
                          Update your build, 2.67 is already available.
                          Support Request
                            Got the similar problem as above. (different lines... how can i add console text? Can't copy-paste from console.)
                            Blender 2.68a (r58537) with the latest exporter (268_bdancer-vb25-5d87489.zip) added as vb25 directory in "c:\Program Files\Blender\blender-2.68a-windows64\2.68\scripts\startup\..." doesn't do nothing (can't render, no material previews...) I just got the similar message in console. //at end - AttributeError: 'VRayMaterial' object has no attribute 'BRDFVRayMtl'
                            V-Ray/Blender Custom Build (VRayBlender-2.6 works OK. Exporter for previous versions (2.66, 2.67) also worked OK.
                            I wish to only use one instance of Blender with VRay & Cycles. So, is there an option to add Cycles to your custom build or any other advice?
