problem with bruteforce
  • problem with bruteforce
    I done an experiment with bf with subdivision 60 and dmc 4-25 light cache 2000 the light is an hdri high quality the problem is the point whithe in the wall,what settings i can tweak to avoid this?
    Re: problem with bruteforce
    How much is the hdri subdivision?
      the hdri on hemi lamp is 20 sub
        Try values around 64, sometimes also this happens to me in dark or in "indirect" light areas.
          I have done an experiment with 120 subd and occour the same .it s strange because the noise threesold is set to 0.002 do u tink the problem maybe in the light cache settings?
            Hum... maybe. Does the problem persist with IM+BF?
              Forgjve me ... but i m out of my home what is IM?
                Sorry, Irradiance Map
                  Excuse it was obvious...the render with IM is decent .i tried to render with bf thinking that gave me a more accurate and more detail but seems only slower sure i m wrong something
                    Could you show your light setup? Are using portals or smth?
                    andrei.izrantcev@chaos.com
                    Support Request
                      Only hdri tried also with hdri vraysun with a problem of innatural reflexion in the ceiling hut this is another problem anyway the subdivision seems not affect the problem the settings of bf was 60 sub and light cache from 1000 to 2000 sub tried also universal settings .I think the problem is not the noise threesol because 0.002 should be an optimal value
