error in geometry vrscene
  • error in geometry vrscene
    When I want to compute a scene vray command line (and deadline too); vray won't start and show me this error
    : Error in file "tmp_fog_geometry_06.vrscene", line 131: expected a "{" at beginning of object definition
    When I open this vrscene, I see that this line (131) define the only object with a dot inside its name. But the brace is there.
    GeomStaticMesh MEP_Balmes_mod_pupille_LLIP_Balmes_mod_pupille.R {
    Indeed, I've a dot into the object name in blender, but when I use Vray with still image inside blender, I've got no errors.
    If I edit manually the vrscene, and I remove the dot, the render start.
    I try to reproduce it in a basic scene, but I can't. I've seen that your exporter always change dots into underscores.
    I don't send you the blend file, because it's an heavy and complex one. This object (MEP_Balmes_mod_pupille_LLIP_Balmes_mod_pupille.R) is inside a linked library and is animated with a proxy armature. This same character doesn't have this problem in other blend files.
    Blender / V-Ray/Blender build version : Blender 2.68.1 for win 7 available from bdancer site
    V-Ray version 2.20.01 core 2.00.01
    Re: error in geometry vrscene
    Could you send me the file with just this mesh? Its really strange that this "." wasn't strip out...
    andrei.izrantcev@chaos.com
    Support Request
      I'll send it by email. It's too heavy for the forum attachment.
      I've noticed something stranged, it seems that " MEP_Balmes_mod_pupille_LLIP_Balmes_mod_pupille.R" doesn't exist in my scene. It could be a concatenation of two names...
        I had to send it with wetransfer. I couldn't lighten the scene without keeping the error.
        With the file I sent you, you just have to hit render animation, and wait... (a long time). Exporter works, but when renderer starts it throws an error on geometry_03.vrscene
        Maybe an error due to memory limit?
          Ok, thanks, I'll check it!
          Support Request
            Hello!
            any news about this issue? I'm still stuck for my network rendering.
              Afair, we've decided that you will send me the master scene, because you have some library links; this name is concatenation of mesh name and library name:
              ME_mesh_nameLL_library_name
              Support Request
                I've send it with wetransfer, but I discover that you never download it... maybe it was in your spam box.
                I'll retry this evening.
                JF
                  Thanks JF, will check it then.
                  Support Request
