V-Ray is not running when file path contains spaces
  • V-Ray is not running when file path contains spaces
    When rendering from a blend file which contains spaces in it´s filepath I get the following debug error:
    Code:
    V-Ray/Blender: Recieve image error: V-Ray is not running
    The same scene renders fine when I put it in a directory with no containing spaces.
    I tried to fix this in the render.py file by putting the scenefile (line 1750) and imgfile (line 1762 + 1831) in double quotes. This is recommended by the command line docs from the V-Ray help page. But it still doesn´t work. Any ideas?
    Thomas
    Re: V-Ray is not running when file path contains spaces
    So the issue is only the message or you're missing some functionality?
    andrei.izrantcev@chaos.com
    Support Request
      I see, I forgot to tell what the problem is. V-ray doesn't render anything. All vrscene files where exported successfully but after that nothing happens just this error.
      Thomas
        Fix in git, please check if it'll work for you.
        Support Request
          By the way, i got the same error with accents.
            Sorry for the late reply. It still doesn´t work.
            Further steps I took to track down the bug:
            - First, I printed out the command that vb25 executes. I found nothing wrong. So I opened my Terminal and tried a very simple cmd-line rendering:
            Code:
            vray -sceneFile="/Volumes/Media/IES Profiles/test blend/vrscene/Lights_scene.vrscene"
            [2013/Sep/23|15:13:20] error: Error parsing command line
            - Escaping the spaces in the path (with \) was my next step:
            Code:
            vray -sceneFile=/Volumes/Media/IES\ Profiles/test\ blend/vrscene/Lights_scene.vrscene
            [2013/Sep/23|15:13:30] error: Error parsing command line
            As you can see I always get the "Error parsing command line" error. But when I render from a directory that does not contain spaces, everything renders fine.
            So the next question is, can anyone with the latest V-Ray Standalone on a Mac confirm this problem? Because I´m not sure if this issue is related to the demo-version which I´m currently using/testing. If confirmed I strongly believe that this is a bug in V-Ray not in vb25.
            Would someone please confirm?
            Thomas
