[Solved] EXR: Am I missing something?
  • [Solved] EXR: Am I missing something?
    I don't know, probably I'm doing something wrong.
    If I save a vray render in exr format and I load it in blender to do some colour correction, I see that all the part of the image that exceed the 100% white is cut.
    You can see here:
    [url=http://imageshack.com/i/0iolwep]
    But if I load the blender internal render I've all the informations as it should be. See here:
    Uploaded with ImageShack.com
    I don't understand why the HDR images outputted by vray are treated as LDR images, is there some hidden preference?
    Re: EXR: Am I missing something?
    Disable "Clamp Output" under "Color Mapping".
    andrei.izrantcev@chaos.com
    Support Request
      Thank you for your reply, but "clamp output" is always disable, and for this it is very strange....
      P.S. Congratulations for your new job. Today Vray-blender is a gret piece of software, but I'm sure that it will become a VERY great piece of software.
        Looks fine for me, try updating the exporter, there were recently some bug found with exr saving (or try saving from V-Ray Frame Buffer manually).
        [attachment=0:2si6k2a0]unclamped_exr.png[/attachment:2si6k2a0]
        Support Request
          I try immediately!
            Just updated (bdancer-vb25-969c255.tar.gz), but the result is stille the same.
            Very strange. It's the same also if I save from the VFB (more strange!).
            I attached the blend file, maybe it can be usefull (http://www.hanaishi.it/files/exr_test.blend)
            P.S. I think that in file render.py there's a bug: line 1833
            Code:
            log_window.append("-e")
            doesn't work in my jessie, but if I move after line 1828 all goes right.
              Thanks for checking log window stuff, will fix it.
              About your issue - Exponential mapping also clamp values a lot (thats why its exponential =), use Linear to archive what you want.
              Support Request
                It's true! Good to know. A vray teacher told me to use "exponential" when indoor, but now it's a thing to evaluate carefully in case of exr.
                Thank you again!
                Yes, not a great bug tracking, just a suggestion
                  Re: [Solved] EXR: Am I missing something?
                  He is not wrong actually, but if you want to control exposure manually in post you have to use some linear mapping.
                  Support Request
