bake problem
  • bake problem
    I have V-ray 2.00 standalone
    And I'cant bake any object. I've used to do that in the past, but no, always get black image. I've even downloaded latest vray demo and build from your site upgraded the script to latest one, and still black Imgae.
    Even simple cube, -> YV Mapped as lightmap, Cube selected as baked object, and it's black. Any ideas?
    Regards Martin
    Ps UV channel is "1" and UV Map is named "1"
    Does anybody know how to bake using Vray?
    Re: bake problem
    Thanks, I'll check this, this looks like some V-Ray changes.
    andrei.izrantcev@chaos.com
    Support Request
      Re: bake problem
      yea i use it at very well
      at this project
      viewtopic.php?f=4&t=1231
      you cant use 2nd chance for baking and u must select Chanel 1 to bake and Chanel 2 to tiling and ...
      if you have problem
      pleas say
      you can use this sample ( i create it for u )
      attached at down[attachment=0:2j4ytf6c]bake test.zip[/attachment:2j4ytf6c]
      I am Programmer,I have no life
        Re: bake problem
        OK
        I've got file, and Error "No Camera"
        How do I turn on baking, Should I use render buton (Image) or there is somewhere hidden button to fire it?
          Re: bake problem
          You have to activate Bake under Render -> Modules and press "Render" and setup params. Nothing hidden.
          Support Request
            Re: bake problem
            sorry
            i forget camera must added befor backing
            camera with any direction and position but must be exist
              Re: bake problem
              Still doesn't work,
              I've downloaded V-ray demo -> Jul 08, 2013 2.30.01 maya2010 32bit and still, got black image with v-ray logo, resolution is OK.
              This is console output
              V-Ray/Blender: Writing scene...
              V-Ray/Blender: Exporting meshes...
              V-Ray/Blender: Exporting meshes done [00:00.29]
              V-Ray/Blender: Writing frame 1...
              V-Ray/Blender: Writing frame 1... done [0.00]
              V-Ray/Blender: Writing scene... done [0.30]
              [2013/Oct/3|12:53:21] Reading configuration from "C:\Program Files\Chaos Group\V
              -Ray\Standalone for x86\vray\bin\/vrayconfig.xml"
              [2013/Oct/3|12:53:21] ===============================================
              [2013/Oct/3|12:53:21] V-Ray Standalone DEMO, version 2.20.01 for x86
              [2013/Oct/3|12:53:21] Copyright (C) 2000-2010 Chaos Group Ltd. All rights reserv
              ed.
              [2013/Oct/3|12:53:21] Use -credits option for additional third-party copyright n
              otices.
              [2013/Oct/3|12:53:21] Build from Jul 4 2013, 14:28:21
              [2013/Oct/3|12:53:21] Compiled with Intel C++ compiler, version 12
              [2013/Oct/3|12:53:21] Operating system is Microsoft(tm) Windows(tm), version 5.1
              , Dodatek Service Pack 3
              [2013/Oct/3|12:53:21] V-Ray core version is 2.00.01
              [2013/Oct/3|12:53:21] Loading plugins from "C:\Program Files\Chaos Group\V-Ray\S
              tandalone for x86/vray/vrayplugins/vray_*.dll"
              [2013/Oct/3|12:53:21] 103 plugin(s) loaded successfully
              [2013/Oct/3|12:53:21] Finished loading plugins.
              [2013/Oct/3|12:53:21] Reading scene file "c:\docume~1\drafts~1\ustawi~1\temp\vra
              yblender_standalone\scene_scene.vrscene"
              [2013/Oct/3|12:53:21] c:\docume~1\drafts~1\ustawi~1\temp\vrayblender_sta ndalone\
              scene_scene.vrscene: done [ 0h 0m 0.0s]
              [2013/Oct/3|12:53:21] scene_camera.vrscene: done [ 0h 0m 0.0s]
              [2013/Oct/3|12:53:21] scene_lights.vrscene: done [ 0h 0m 0.0s]
              [2013/Oct/3|12:53:21] scene_nodes.vrscene: done [ 0h 0m 0.0s]
              [2013/Oct/3|12:53:21] scene_materials.vrscene: done [ 0h 0m 0.0s]
              [2013/Oct/3|12:53:21] scene_environment.vrscene: done [ 0h 0m 0.0s]
              [2013/Oct/3|12:53:21] scene_textures.vrscene: done [ 0h 0m 0.0s]
              [2013/Oct/3|12:53:21] scene_geometry_00.vrscene: done [ 0h 0m 0.2s]
              [2013/Oct/3|12:53:21] scene_geometry_01.vrscene: done [ 0h 0m 0.0s]
              [2013/Oct/3|12:53:21] scene_geometry_02.vrscene: done [ 0h 0m 0.0s]
              [2013/Oct/3|12:53:21] scene_geometry_03.vrscene: done [ 0h 0m 0.0s]
              [2013/Oct/3|12:53:21] Scene file parsed successfully in 0.2 s.
              [2013/Oct/3|12:53:21] warning: Unknown property "progressive_showMask" in object
              "SettingsImageSampler"
              [2013/Oct/3|12:53:21] warning: Unknown property "progressive_bundleSize" in obje
              ct "SettingsImageSampler"
              [2013/Oct/3|12:53:21] warning: Unknown property "progressive_maxTime" in object
              [2013/Oct/3|12:53:21] warning: Unknown property "progressive_threshold" in objec
              [2013/Oct/3|12:53:21] warning: Unknown property "progressive_maxSubdivs" in obje
              [2013/Oct/3|12:53:21] warning: Unknown property "progressive_minSubdivs" in obje
              [2013/Oct/3|12:53:21] Scene created successfully.
              [2013/Oct/3|12:53:21] Objects in scene: 34
              [2013/Oct/3|12:53:21] Starting render sequence.
              [2013/Oct/3|12:53:21] Preparing renderer...
              [2013/Oct/3|12:53:21] Preparing scene for rendering...: done [ 0h 0m 0.0s]
              [2013/Oct/3|12:53:21] Starting frame 0.
              [2013/Oct/3|12:53:21] Preparing scene for frame...: done [ 0h 0m 0.0s]
              [2013/Oct/3|12:53:21] Compiling geometry...: done [ 0h 0m 0.0s]
              Building static raycast accelerator...: 0.00% [ 2h 9m 51.4s] [ 0h 0m 0.0s es
              [2013/Oct/3|12:53:21] Building static raycast accelerator...: done [ 0h 0m 0.0
              s]
              [2013/Oct/3|12:53:21] SDTree statistics:
              [2013/Oct/3|12:53:21] Total number of faces stored: 15362
              [2013/Oct/3|12:53:21] Max tree depth: 26
              [2013/Oct/3|12:53:21] Average tree depth: 17.8509
              [2013/Oct/3|12:53:21] Number of tree nodes: 8899
              [2013/Oct/3|12:53:21] Number of tree faces: 41868
              [2013/Oct/3|12:53:21] Number of tree leafs: 3146
              [2013/Oct/3|12:53:21] Average faces/leaf: 13.3083
              [2013/Oct/3|12:53:21] Memory usage: 1.31 MB
              [2013/Oct/3|12:53:21] Tracing 1000000 image samples for light cache in 4 passes.
              [2013/Oct/3|12:53:22] Building light cache...: done [ 0h 0m 0.3s]
              [2013/Oct/3|12:53:22] Merging light cache passes...: done [ 0h 0m 0.0s]
              [2013/Oct/3|12:53:22] Light cache contains 0 samples.
              [2013/Oct/3|12:53:22] Prefiltering light cache...: done [ 0h 0m 0.0s]
              [2013/Oct/3|12:53:22] Prepass 1 of 1...: done [ 0h 0m 0.0s]
              [2013/Oct/3|12:53:22] Rendering image...: done [ 0h 0m 0.0s]
              [2013/Oct/3|12:53:22] Number of raycasts: 0
              [2013/Oct/3|12:53:22] Camera rays: 0
              [2013/Oct/3|12:53:22] Shadow rays: 0
              [2013/Oct/3|12:53:22] GI rays: 0
              [2013/Oct/3|12:53:22] Reflection rays: 0
              [2013/Oct/3|12:53:22] Refraction rays: 0
              [2013/Oct/3|12:53:22] Unshaded rays: 0
              [2013/Oct/3|12:53:22] Number of intersectable primitives: 15362
              [2013/Oct/3|12:53:22] SD triangles: 15362
              [2013/Oct/3|12:53:22] MB triangles: 0
              [2013/Oct/3|12:53:22] Static primitives: 0
              [2013/Oct/3|12:53:22] Moving primitives: 0
              [2013/Oct/3|12:53:22] Infinite primitives: 0
              [2013/Oct/3|12:53:22] Frame took 0.34 s.
              Any Idea?
                Re: bake problem
                i see this problem from imported models
                for example my new game model created from 3Dsmax when i import it to blender - after changing material to Vraymaterial-in blender and press render to bake i see black render process ( and it done less than 5 sec )
                  Re: bake problem
                  I've made a few fixes and hope it won't be very confusing. Now you could name your channels as you want, but in the Bake options you have to enter its index.
                  Here is a example:
                  [attachment=0:3tyxxrx8]vb25_bake.png[/attachment:3tyxxrx8]
                  So, in this example the "Bake" channel will be used.
                  Support Request
