Alpha / Transparency problems
  • Alpha / Transparency problems
    Dear Andrey,
    I attach a render, from an X-Frog model of a small shrub. I am using separate alpha and diffuse maps. Each branch / leaf is a plane with a UV mapped diffuse image / opacity map. The vb version is from 2 days ago (20140502).
    As you can see, there is a strange black area in the middle, as if the rays give up trying to get through.
    Even stranger, the alpha output from V-Ray shows these areas as transparent.
    I can't post the scene as its property of X-frog, could you tell me if this is a bug, or if I've just missed some setting? Thanks in advance!!
    Regards,
    Rob.
    the issue is transparency depth in the material. Once you exceed the depth, that's what happens. I've seen it on other plants like that. Two solutions:
    1. increase your transparency depth for your material
    2. reduce the amount of geometry in your plant.
      Cheers Andy!
      I though there may be a simple answer!
      Rob.
        Hi Andrey,
        Tried to update the exporter as you said in email, and this came up. I have a strong internet connection though!
        R
          ockelford, looks like some change in Python 3.4, I'll will rewrite the update function and upload new build asap.
          andrei.izrantcev@chaos.com
          Support Request
            Thanks Andrey,
            Rob
            PS - Everytime I open blender if find something else that's been improved / fixed. I just can't wait till the Vray3.0 upgrade for Maya licensees is available. Are nodes in the vb3.0 version yet?
              It's work in progress, but you could try playing with it - download a build with -vb30- in name then chech the wiki: https://github.com/bdancer/vb30/wiki and https://github.com/bdancer/vb30/wiki/Nodes-Layout
              Support Request
