error enabling vb30
  • error enabling vb30
    hi
    i try to enable vb30 which is downloaded from github and put in addon folder in blender patched with vray exporter but i get this error:
    Code:
    RNA_pointer_get: Object.vray not found.
    Traceback (most recent call last):
      File "C:\blender\win64-vc12\2.72\scripts\modules\addon_utils.py", line 299, in
     enable
        mod = __import__(module_name)
      File "C:\blender\win64-vc12\2.72\scripts\addons\vb30\__init__.py", line 38, in
     <module>
        from vb30 import preset
      File "C:\blender\win64-vc12\2.72\scripts\addons\vb30\preset.py", line 31, in <
    module>
        from vb30.vray_tools.VRaySceneParser import ParseVrscene
    ImportError: No module named 'vb30.vray_tools.VRaySceneParser'
    <!> event has invalid window
    Blender quit
    i can verify that:
    -vb25 works ok in this build.
    -vb30 is put in the addon folder in blender alone with no vb25 installed.
    -vray for standalone from maya 2012 is working and rendering with vb25.
    -vray version is 20004
    -os is windows 8.1 x64
    is there something wrong on my end?
    thanks.
    It could, but it's not supposed to =)
    You have to clone vb30 with submodules with --recursive flag like this:
    Code:
    git clone --recursive https://github.com/bdancer/vb30.git
    andrei.izrantcev@chaos.com
    Support Request
      ok now it is enabled, thank you.
        hi got this error today, is it expected:
        Code:
         enable
          File "C:\blender\win64-vc12\2.72\scripts\addons_extern\vb30\__init__.py", line
         42, in <module>
            from vb30 import engine
          File "C:\blender\win64-vc12\2.72\scripts\addons_extern\vb30\engine.py", line 6
        0, in <module>
            class VRayRendererPreview(VRayRendererBase):
        5, in VRayRendererPreview
            bl_preview_filepath = SysUtils.GetPreviewBlend()
          File "C:\blender\win64-vc12\2.72\scripts\addons_extern\vb30\lib\SysUtils.py",
        line 179, in GetPreviewBlend
            return os.path.join(GetExporterPath(), "preview", "preview.blend")
          File "C:\blender\win64-vc12\2.72\python\lib\ntpath.py", line 108, in join
            result_drive, result_path = splitdrive(path)
          File "C:\blender\win64-vc12\2.72\python\lib\ntpath.py", line 159, in splitdriv
        e
            if len(p) > 1:
        TypeError: object of type 'NoneType' has no len()
        trigger device changed
        32x30 (30x18 tiles)
         enable
         37, in <module>
            from vb30 import plugins
        ImportError: cannot import name 'plugins'
          crax, I'm not experiencing this, try full rebuild.
          Support Request
            @bdancer: this is a full rebuild, i tested with single building thread, default profile. vs2013, mingw x64, windows 8.1 x64, it worked before!, should i do something?
            thank you.
              crax, drop me an email at andrei.izrantcev@chaosgroup.com, will try to figure it out.
              Support Request
                sorry, i'm not following you, what should i email you with? if you mean a build log i'll happily send it to you.
                  Acatully I planned to connect with teamviewer and check whats wrong, because I'm making builds fine there without any problems with my build script (https://github.com/bdancer/vb25-patch/wiki/autobuild).
                  Support Request
                    i don't mind using teamviewer, but the problem is i don't have full internet connection, i use mobile internet when i need something, so i guess it couldn't work.
                    if you want any info i will provide it to you, one thing to notice is that i've build vray 2 weeks ago and it worked, the error happened after i updated the branch.
                    i'll try test what version worked and post my results -Aw-
                      ok i tried with different versions of the exporter and the branch, still the same error, help
                        Try using my autobuild script (I'm making my builds with it without any issues) or precompiled builds.
                        Support Request
                          ok
                          i found that it the plugin doesn't work from either external or contrib addon folder, and i didn't see it mentioned anywhere that it should only be in "addon" folder, even in github wiki.
                          now it works.
