error message when rendering
  • error message when rendering
    Hi, an error message shows frequently when I render a frame, that causes Blender to crash:
    libc++abi.dylib: terminating with uncaught exception of type std::bad_alloc: std::bad_alloc
    Abort trap: 6
    logout
    I've tried different lighting methods, for animations and stills and it's the same.
    I'm on VRay 3.0, Blender 2.74 and exporter is updated. Thanks for the help.
    Is the scene huge? How much RAM do you have? Could you send me a scene?
    andrei.izrantcev@chaos.com
    Support Request
      Hi Andreï,
      no, the scene is not that big, I have 32Gb of RAM, I'm sending you the scene via WeTransfer.
      When I tried to render an animation, or just calculate the Light Cache, it crashes every two or three frames.
      Thanks.
        I've uploaded a new build, pls, check if it works for you. Also I think its better to use "Full Range (Camera Only)" mode since you are only camera movement.
        Support Request
