Dear Chaos,
i've downloaded your last nightly build of Vray Standalone 3 SDK (vraystd_adv_32501_x64_vc101_hwlic_25805) and the last Blender for Vray (vrayblender3-2.74-60092-dfbb876-fd9aca6-x86_64-windows).
Locally it works but DR doesn't.
On the slave I've installed just the Vray for Standalone. Then I created a link to vray.exe with the -server and -portnumber options.
I've started the vray.exe on the slave and I can see it in the slave list of the master so the license is ok.
I've tried to launch a DR render (the startup scene) with the option to use only the slave but it doesn't start and the master says me:
[2015/May/19|15:46:00] warning: Could not connect to host 192.168.96.65:20207: Connection timeout
[2015/May/19|15:46:00] warning: Could not use any of the selected (1) hosts for distributed rendering!
[2015/May/19|15:46:00] warning: Local machine is not used for distributed rendering and no slaves can join!
First of all a question: why if I set 20204 port both in Blender and in the slave, it seems that vray is still searching for a slave on the port 20207?
I tried to change the port to 20207 both in Blender and in the slave but with no luck, it still searching a slave without found it.
Where am I wrong?
Thanks in advance
Where am I wrong?
Thanks in advance
