Linked duplicates with modifiers
  • Linked duplicates with modifiers
    renders all linked duplicates (Alt+D) with last created linked duplicate modifiers.
    I dont know if this is intentional but its different how blender render works.
    I know I can turn off System > Exporter > [ ] Alt+D instances but then I will lose all its benefits.
    Win11 Pro 64bit, GTX 970, Standalone version: V-Ray Next 4.30.03,
    I'll try to optimize it, I've found some api function that could determine if alt-d instance could be actually instantiated.
    andrei.izrantcev@chaos.com
    Support Request
      Example: object1 has subsurf modifier and object2, which is is linked duplicate from object1, has no modifiers. Render result is both objects are without modifiers.
        Pls, try the new build in the nightlies.
        Support Request
          Yes, linked duplicates with different modifiers works, thank you. You have done a very good job of adding important options. Lucky us they hired you.
