Hello,
it looks like it is not consistent which layer is used to edit the material nodes for an object. For examle if i click on Material 1 while i am in the "VRay Node Tree Editor" i can remove every node but the material preview doesn't change because the changes actually affected Material 2 which is assigned to the same object.
So which node editor button do i have to use to edit the material?
