I worked on Blender VRAy 2.76. Then I opened the file with the vanilla Blender 2.77 and save it. Now when I try to reopen the file with Bender VRay, it crashes when I select an object to see its material. I downloaded a new version of Blender VRay in the nightlies, but it's still the same. If I append an object from this file, I get the same result.
This is the error message:
Thanks for the help.
Code:
V-Ray For Blender: Parsing plugin descriptions... done [00:00.14] addon not found: 'RenderStreet' Particle Link | Add-on Activated read blend: /Users/Bupla/Documents/Projets/Merial_2/tests_Merial/Merial_IB1.blend Error, region type 2 missing in - name:"File", id:5 Particle Link | Add-on Activated V-Ray For Blender: Exporting data for frame 0... V-Ray For Blender: Exporting data for frame 0 done [00:00.00] Fatal Python error: Segmentation fault Current thread 0x00007fff7313b000 (most recent call first): File "/Applications/ChaosGroup/Blender 2.77 (With V-Ray Additions)/blender.app/Contents/Resources/2.77/scripts/addons/vb30/ui/classes.py", line 206 in NtreeWidget File "/Applications/ChaosGroup/Blender 2.77 (With V-Ray Additions)/blender.app/Contents/Resources/2.77/scripts/addons/vb30/ui/properties_material.py", line 43 in RenderMaterialPanel File "/Applications/ChaosGroup/Blender 2.77 (With V-Ray Additions)/blender.app/Contents/Resources/2.77/scripts/addons/vb30/ui/properties_material.py", line 122 in draw Writing: /tmp/Merial_IB1.crash.txt Segmentation fault: 11 logout Saving session... ...copying shared history... ...saving history...truncating history files... ...completed.
