Shadow Granularity - Subdivs in Light Panel having no effect
  • Shadow Granularity - Subdivs in Light Panel having no effect
    According to the Author of Photography & Rendering with V-Ray (page 52 in case you have it), I should be able to change the Subdivs value in the Light panel from 8 to 30 and get rid of the grain in the shadow until it is indiscernible at the cost of increased render time. However, when I change the value from 8 to 30, the shadow grain is identical as is the render time. There is no difference in either render, before or after. I conclude from this that this Subdivs value isn't working as it should be. Can someone confirm this or tell me what I am missing?
    Thanks,
    Bryson
    BTW.. here is the blend file
    https://onedrive.live.com/redir?resi...int=file%2czip
      Use Local Subdivs
      Win11 Pro 64bit, GTX 970, Standalone version: V-Ray Next 4.30.03,
        Ahh, thank you very much!
          Just curious....Is there any approach to solve IR blotches with the new 3.3 method (Use Local Subdivs=OFF)? Any official recomendation on this?
          Checking on "Use Local Subdivs", v-ray will work like it used to be until 3.3.
          architect at oona
            IR blotches were caused by incorrect interpolation menu items and it's fixed.
            andrei.izrantcev@chaos.com
            Support Request
