I am seeing this error in some files. It's not in every file, seems it's only a few recent ones. I grabbed an object out of a larger file that gives this error. It doesn't seem to effect the rendering, but thought I should make a note of it. The error comes up when I first open the file.
"Error while loading ntree. Wrong data found in file!"
I haven't been using the convert to nodes tool as much lately because the conversion of textures is still causing an error and stopping the conversion.
http://forums.chaosgroup.com/showthr...to-nodes-error
This means there is an invalid reference to a nodetree, and that nodetree was not found in the saved file. Previously loading such scenes was causing a crash which is now avoided.
Everything saved should be loaded correctly from now on, but if you find that there are missing node trees please report.
Originally posted by poseidon4o View PostThis means there is an invalid reference to a nodetree, and that nodetree was not found in the saved file. Previously loading such scenes was causing a crash which is now avoided.
