Output node limitation
  • Output node limitation
    Some options of the texture "Output Node" are not working as expected.
    "Output Mult", "Color Mult" and "Color Offset" are displayed as color fields limited to 0-1 range.
    In Max, their equivalent fields "Output Amount", "RGB Level" and "RGB Offset" are numerical and not limited to 0-1 range.
    This node has many potencial uses (eg: adjusting brightness and constrast), but with its range limited to 0-1 make it a bit useless.
    architect at oona
    I haven't tested yet but if set the "value" color upper than 1..is it clamped to 1 or not?
      Yes, they're limited to blender colorfield range (0-1).
      If I set a number a value greater than 1 it gets clamped to 1 and if I set a negative value it gets clamped to 0.
      architect at oona
