Problems with displacement on quad faces
  • Problems with displacement on quad faces
    I am playing with textures using the default scene. For the displacement, I am using the following texture:
    In the default scene I unwrap the cube, I create a new V-Ray node tree and add a Displacement node connected to an Image File node using the previous texture:
    But the final rendered image shows a weird triangulation issue:
    But then, if I convert the mesh from quads to triangles:
    the render is fine:
    The issue seems to happen when the mesh is built with quads, but not when using triangles.
    Does it help if you subdivide the box a little bit (i.e. give it a few more segments on each side rather than one large quad)?
      I think its current exporter problem, here the last Blender build with old exporter (2017.01.19) and Vray Standalone today build (vraystd_adv_35701_x64_vc11_hwlic_27259.rar).
      Displacement mode: 2d. Default cube, 6 quads.
      Win11 Pro 64bit, GTX 970, Standalone version: V-Ray Next 4.30.03,
        You are right, Vlado. Adding more segments solves the issue. Thanks for pointing it!
        EDIT: To my surprise, after installing the latest build (20170306) I can not reproduce the issue anymore... good
