Array modifier last not render correctly
  • Array modifier last not render correctly
    Last array modifier has [x] object offset. If I add Simple Deform modifier the last one and set it to no render, array modifiers works.
    Using the latest Blender for Vray version.
    Blend file
    Win11 Pro 64bit, GTX 970, Standalone version: V-Ray Next 4.30.03,
    Same wrong render also when array modifier is the last modifier and Start and End caps are there.
      Offset object should start working from next nightly. Cap objects only for first array mod will also work from next build.
