Small automatic zoom vfb only.
  • Small automatic zoom vfb only.
    In frames 77 to 79 and 106 to 107. makes an unexpected small zoom.
    Look at the correct animation captured on the screen with OpenGL and then the error in the final render.
    This is a big problem, I'm waiting.
    Thanks!!
    PablonchoWorks Can you upload a scene that reproduces the issue please?
      poseidon4o
      I have resolved in (after effects) with the animation of a null object. I hope you have good luck in the solution.
      Thanks anyway.
        PablonchoWorks I noticed in your scene the camera Angle is animated, which produces this zoom effect. If you remove the angle keyframes there should be no zoom.
          Thanks Poseidon4o!
          I know it has animation, is part of the piece.
          The strange thing is there are no problems in the viewport. But if it presents a problem within the final render.
          Angle of aperture of the lens is present in the values of camaravray. I can control what I see through the camera in the viewport.
          Is this camera preview tool something not recommended to use?
          If so, it would be a real shame.
          thanks anyway.
          sorry for my english.
            Not sure if it would give you the same result, but can you just change the camera field of view instead?
              PablonchoWorks Check in this video, I have attached a cube to the camera and moved it in front. The zoom becomes apparent even in the viewport:
              https://dl.dropboxusercontent.com/s/...0_19-33-27.mp4
