I am using 3 computers, two of them are distributed rendering slaves at home, one at work right now. I get weard results when trying to apply Displacement effect on ground plane, to see this weard result i used edges texture.
different subdivision level with displacement and distributed rendering
if thats helps this is output from terminal
[2017/Jul/24|11:45:46] Unknown property "environment_geometry" in object "Geom@MEPlane"
[2017/Jul/24|11:45:46] Unknown property "uv_set_name" in object "Mapping@NTLamp|NImage_File"
https://expirebox.com/download/4d711...d63d29f71.html here is simple file, result is the same, with cube and plane.
Make sure you have the same V-Ray version on all of your nodes.
[2017/Jul/24|13:16:08] Reading configuration from "/usr/ChaosGroup/V-Ray/Standalone_for_linux_x64/bin/linux_x64/gcc-4.4//vrayconfig.xml"
[2017/Jul/24|13:16:08] ===============================================
[2017/Jul/24|13:16:08] V-Ray Standalone, version 3.61.01 for x64
[2017/Jul/24|13:16:08] Copyright (C) 2000-2017 Chaos Group Ltd. All rights reserved.
[2017/Jul/24|13:16:08] Use -credits option for additional third-party copyright notices.
[2017/Jul/24|13:16:08] Build 27448 from Jun 7 2017, 05:09:40
[2017/Jul/24|13:16:08] Compiled with GCC-compatible compiler, version 4.4
[2017/Jul/24|13:16:08] Operating system is Linux
[2017/Jul/24|13:16:08] V-Ray core version is 3.61.01
[2017/Jul/24|13:16:09] Loading plugins from "/usr/ChaosGroup/V-Ray/Standalone_for_linux_x64/bin/linux_x64/gcc-4.4/plugins/libvray_*.so"
[2017/Jul/24|13:16:09] 83 plugin(s) loaded successfully
[2017/Jul/24|13:16:09] Finished loading plugins.
[2017/Jul/24|13:16:09] Using folder "/tmp/vray_assets_cache" for caching assets for DR.
[2017/Jul/24|13:16:09] Using file "/tmp/vray_assets_cache/cache_info_20207.txt" for storing assets cache information.
[2017/Jul/24|13:16:09] Entering server mode - waiting for render requests on port 20207. Press Ctrl+C to exit.
[2017/Jul/24|13:16:21] Reading configuration from "/usr/ChaosGroup/V-Ray/Standalone_for_linux_x64/bin/linux_x64/gcc-4.4//vrayconfig.xml"
[2017/Jul/24|13:16:21] ===============================================
[2017/Jul/24|13:16:21] V-Ray Standalone, version 3.61.01 for x64
[2017/Jul/24|13:16:21] Copyright (C) 2000-2017 Chaos Group Ltd. All rights reserved.
[2017/Jul/24|13:16:21] Use -credits option for additional third-party copyright notices.
[2017/Jul/24|13:16:21] Build 27448 from Jun 7 2017, 05:09:40
[2017/Jul/24|13:16:21] Compiled with GCC-compatible compiler, version 4.4
[2017/Jul/24|13:16:21] Operating system is Linux
[2017/Jul/24|13:16:21] V-Ray core version is 3.61.01
[2017/Jul/24|13:16:22] Loading plugins from "/usr/ChaosGroup/V-Ray/Standalone_for_linux_x64/bin/linux_x64/gcc-4.4/plugins/libvray_*.so"
[2017/Jul/24|13:16:22] 83 plugin(s) loaded successfully
[2017/Jul/24|13:16:22] Finished loading plugins.
[2017/Jul/24|13:16:22] Using folder "/tmp/vray_assets_cache" for caching assets for DR.
[2017/Jul/24|13:16:22] Using file "/tmp/vray_assets_cache/cache_info_20207.txt" for storing assets cache information.
[2017/Jul/24|13:16:22] Entering server mode - waiting for render requests on port 20207. Press Ctrl+C to exit.
ok i reinstal the builds in two linux slaves, and windows master, and this magic efect still happening if i check in exporter "Use cached assets on DR" and "Check Assets Cache"
And what if you uncheck those settings? Transfer asstets will transfer only new assets anyway.
ok this morning at work when i tryed to start my slaves pc at home, my licence server stoped working, and i get message cant get licence code (111)
so i downloaded oficial standalone from chaosgroup
and reinstall licence server and stand alone for linux, no i made that at work for windows master too. and it works perfectly. after that licence server asked to register my acount, and licences at home computers works now perfect.
my problems were when i was using this builds
I was changing edges length parameter when my problems were shown in render.
I've made an issue for the support team about this, we'll see what they'll say.
yesterday after reinstalation I wrote there that it works fine, but after few tests it starts to render same with that issue, but i cant that test any moore, bicause i quit working at that company. and will not use that computer and windos os any more, i tested at home displacement on two linux computers (one master and other slave) and it renders correctly, maybe there was some issue with that windows set up, windows computer was split for two users with "Aster" program that makes availability to use multiple users and work places on same computer
