I have tried to render using RT OpenCL engine (V-Ray Standalone for Linux 3.6.03) using CPU (i7-4770K) and Nvidia GTX 770 (driver 375.66 on Kubuntu 17.04) from Blender (With V-Ray Additions, nightly 2017-08-15), but it failed with "cl_nv_compiler_options extension not found." error like this:
Do I have to install some packages, or my card does not support OpenCL as needed..?
Thanks!
Code:
2017/Aug/15|13:23:20] OpenCL program built in 79.628 s [2017/Aug/15|13:23:20] Kernel binary cache saved successfuly at /tmp/vray_ocl_cache_2017_08_01_14_36GeForce GTX 770_x64_ubt_moblur_lc_cp_lm_lrs_375.66.clbin [2017/Aug/15|13:23:20] Driver version 375.66 [2017/Aug/15|13:23:20] cl_nv_compiler_options extension not found. [2017/Aug/15|13:23:20] Failed loading precompiled binary (0) [2017/Aug/15|13:23:20] warning: Building OpenCL trace program for device Portable Computing Language_pthread-Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz. That build is made only the first time you run V-Ray on a particular hardware, but it might take a while. 5 warnings and 1 error generated. Error Program build failure (-11) at line 2170 , in file ./src/opencl_main.cpp !!! [2017/Aug/15|13:23:22] warning: Failed to compile OpenCL kernels, falling back to CPU code. [2017/Aug/15|13:23:22] error: buildProgram() failed for device 1 (-11)! [2017/Aug/15|13:23:22] warning: initDevices() failed. Please check that your system has compatible GPU devices installed. [2017/Aug/15|13:23:22] Tracing 1000000 image samples for light cache in 64 passes. [2017/Aug/15|13:23:22] Closing RTEngine (cancelled)
Thanks!
