hello i am still unable to use newer builds than 2018 02 15. todays build crashed during startup
Vray blender linux build 2018 03 22 vrayblender35-2.79-52e72c7-x86_64-centos7.2.1511 crashes during starting the program
Try today's build, loads fine for me on my CentOS 7.x VirtualBox node.
Ok, then which add-ons should I enable?
1. I use blender ofitial releaces and vray blender builds. This is screen shots of plugins that are enabled in blende dayly builds used from here https://builder.blender.org/download
2. There are few of them that are purtchased and i can not use of them in blendervray because they are conflicting or something else, if you need i can zip all addons folder and send to You.
3. What exact list of adons are conflicting i dont know, because list is long. If you need i can ask help of my friend to try to debug and send output.
4. I mentioned why i use in Linux Kubuntu 17.10 vrayblender build date of 2018 02 15 and in this buld there is no COLADA exporter importer in vrayblender linux vertion, JuhaW use windows and in his printscreen in vrayblender windows vertion there is COLADA importerexporter
5. Vrayblender (2018 02 15 build day) UV do'nt do corrent aspect ration uv unwraping acording to image (texture) aspect ration. What i mean is that unwrap lets say a cupe on 1024x1024 texture, than change to another texture that are 2048x1024 and UV proportions will be not squeres but deformed rectangles
2. This we'll be helpful.
5. We are not changing any of the core features, probably the source revision used for the build was containing a bug. We'll sync the sources.
