Denoiser render passes question.
  • Denoiser render passes question.
    Does VrayDenoiser affect separate render passes as well or just the final RGB color? Trying to get a denoised reflection pass with no luck.
    Check that the reflection setting in the material is enabled for "all channels"
      Thanks Andy. Unfortunately, I've already tried this and it doesn't seem to make any significant difference. Here's a test.
      I've used a high noise threshold to illustrate the issue. The RGB is significantly better but the Reflection pass is almost identical.
      I'm using vray next btw.
        What does your material setup look like?
          A very basic reflective material with .7 glossiness for test purposes.
            I asked this about 2 years ago and answer was Denoiser Tool.
            https://forums.chaosgroup.com/forum/...denoiser-is-on
            Win7 Ultimate 64bit, GTX 970, Standalone version: V-Ray Next 4.30.03,
              bummer It's going to be kind of cumbersome.
              I'll give that a try see how it goes.
              Thanks for the tip.
                That's too bad. Thanks JuhaW I thought it was possible but looks like my recollection was incorrect.
