since I can't find anywhere else to ask this, I do it here.
1) Is there a possibility to get the samplerate pass out of Vray 2.0 using Vray Blender 2.73? I can not find a corresponding render channel node in the "Add" -> "Render Channels" menu.
2) Is is possible to use Falloff or VectorCurve nodes as weights in the Layered BRDF Node? For example, if I want to weight materials by angle, so that a coating material is less visible at low viewing angles.
Thanks in advance!
Thanks in advance!
