Vray Dirt - Exclude Options
  • Vray Dirt - Exclude Options
    Another feature suggestion.
    Vray dirt is very useful in adding details to small corners.
    I'm just missing a way to exclude some objects or materials from its pass. (eg.: transparent glass frames in a archviz shot)
    More info and examples here:
    http://www.workshop.mintviz.com/tutoria ... ugh-glass/
    Regards.
    architect at oona
    Re: Vray Dirt - Exclude Options
    Done!
    andrei.izrantcev@chaos.com
    Support Request
      Thanks for your fast feedback.
      I'm still getting a result different from tutorial. (I don't know if what I want is even possible in vray standalone)
      Steps:
      - I've excluded glass group from vray dirt and ticked work with transparency in the texture panel.
      - In the glass material settings, I set refraction to affect all channels.
      - Glass is not casting/receiving AO, but still visible in the dirt pass. Any workaround?
      (blend file attached)
      [attachment=1:3hwny6qx]dirt.blend[/attachment:3hwny6qx]
      architect at oona
        Oh, you mean dirt pass. I'll check how to archive this.
        Support Request
          Yeap. I did it via Render Elements > ExtraTex > VrayDirt Texture.
          Thanks!
          architect at oona
            You can exlude glass object from the render on blender outliner...
            Arquitecto is just a very nice architect in Portugal ...
              I wanted to exclude just from AO pass, not from full render pass.
              architect at oona
                Workaround commited to git: select glass object, under Object panel enable Wrapper and uncheck "Generate Render Elements".
                Support Request
                  wow Thanks Andrew! That's great!
                    Thanks bdancer, it's working perfectly!
                    architect at oona
