VRmat node material selection
That's not possible, all of this materials could be used as a material so script could not guess which exactly you want to use. I'll think of some sort of workaround anyway...
Yes I found that if I dont select round edges option, it will not render round edges. Is there a way to know which one to select that is identical than original material ?
I made a script which uses your nodetools > export selected nodetree code, it saves all proxy object materials(with slot number) to single .vrscene file so I can later use Vrmat node to recreate original materials. Now when I load .vrscene file, it has like 4 materials, Vrmat node option has like 12 optionsWin7 Ultimate 64bit, GTX 970, Standalone version: V-Ray Next 4.30.03,
There is an option when importing vrscene so select the base of the material (e.g. which plugin to use as the material). You could check nodes/operators/import_file.py:150 ImportMaterials().
Depending on it you could have more or less imported materials.
Vrmat node menu simply shows all supported types.
Oh yes thats a good function, I will use that and basematerial standard. I will figure out how to add all imported materials to corrects slots (for proxy use). Thanks a lot !Win7 Ultimate 64bit, GTX 970, Standalone version: V-Ray Next 4.30.03,
Before saving nodetrees, I changed one node name before material output node so I recognize it later as original material. And when importing materials back I took all three standard, multi and wrapper types to make sure original material is there. Little bit complicated
I dont know is it correct but seems that original material node block is always the last block of each materials of the .vrscene file.Win7 Ultimate 64bit, GTX 970, Standalone version: V-Ray Next 4.30.03,
