Frame stamp options
  • Frame stamp options
    To set GI primary/secondary engines and result is BF/IM/LC.
    Win7 Ultimate 64bit, GTX 970, Standalone version: V-Ray Next 4.30.03,
    My proposal for Color Correction node default setting is:
    Show Adv Rgb Offset inside the node and all green marked areas.
    Cons:
    + Quickly change any texture hue by changing Offset color
    + Compatible with Gpu render (RT render)
      Edit: Show Adv Rgb Offset inside the node and all green marked areas are by default.
