Hi, would be possible to implement this options in Vray/Blender please? (It looks like they are already in the standalone.)
Vray Sky = "blend angle" and "horizon offset"
Aerial Perspective = "affect background"and "fliter color"
TexSky
blend_angle: float = 5.73917, The angle (in degrees) (up from the horizon) where the sky starts to blend with the ground albedo. Values close to 0.0 produce a sharper horizon line, while larger values produce a softer horizon line.
horizon_offset: float = 0, Horizon offset under the sky-dome. Allows the user to manually lower the horizon line.
VolumeAerialPerspective
affect_bg: bool = true, Specify whether aerial perspective is applied to the background.
filter_color: color = Color(1, 1, 1), Filter color for the fog. Note that fog color depends on the color of the sky.
