V-Ray 6 for Cinema 4D Update 2.5 is now available
  • V-Ray 6 for Cinema 4D Update 2.5 is now available
    Hey everybody,
    V-Ray 6 for Cinema 4D, Update 2.5 is out.
    ​​​​​​The builds can be downloaded from the Downloads section on our site.
    Here is the change log for release version 6.20.05
    Modified features:
    • Add support for instance rotations for the new Particle Emitters
    • Add support for User Data Tag
    • Handle scene-linear Rec.709-sRGB and ACEScg bitmap import
    • Add -skipHome command when initiating LiveLink to prevent the Vantage Home screen from appearing​
    Bug fixes:
    • Incorrect result with animated Bend Deformers in V-Ray Standalone
    • Missing "Vertical FOV" setting in the Overrides settings when the Camera is set to Spherical Panorama
    • Freeze when Render Node License error is encountered
    • Light Cache build fails at start of build, crashing of V-Ray GPU
    • Fix crash with new default camera
    • Crash when an empty Instance object is used
    • Particles will render earlier than expected in V-Ray Standalone
    • Node material previews in some scenes will be refreshed after loading
    • Cinema 4D crashes when reloading cosmos assets
    • Chaos Scatter is always re-exported during interactive rendering
    • V-Ray Material does not support animation for Cinema 4D Noise Shader
    • V-Ray crashes when a source with object properties tag is cleared from Enmesh
    • Animated material change is not functioning in V-Ray Standalone
    • Color management problems in Cinema 4D 2025
    • Material Override does not work without a material
    • Materials are not linked to selections when importing a V-Ray scene containing Multi/Sub-Object
    • Interactive does not update any V-Ray Volume Grid​
    Ivan Shaykov
    chaos.com
