Conversion of scеnes saved with V-Ray 3.7
This is a sticky topic.
  • Conversion of scеnes saved with V-Ray 3.7
    Conversion of scenes created with V-Ray 3.7 for Cinema 4D
    The conversion of scenes created with V-Ray 3.7 or 3.6 for Cinema 4D is based on changing each material, object, shader or setting to its new equivalent counterpart. The process is destructive for the old scene, but to ensure no data is lost, the scene name is changed to prevent overwriting the old scene.
    Known issues and limitations
    • Render Settings:
      • Min Shading Rate is forced to 6.
      • DMC settings are not converted (except for Time Dependent). Use local subdivs is disabled.
      • Linear workflow is disabled.
      • Primary GI engine is forced to Brute Force.
      • Secondary engine is forced to Light Cache, if it is not Brute Force.
      • Light Cache map mode is forced to Single Frame, if it is not From File.
      • Use of Embree is forced to On.
      • Stereoscopic camera settings are not converted (not supported yet).
      • Lens effects settings are not converted.
    • Materials:
      • V-Ray Standard Material:
        • Opacity source is forced to Color and Opacity mode to Stochastic. Grayscale values are converted to color.
        • Highlight glossiness is removed.
        • Translucency type is forced to Volumetric, if enabled.
      • V-Ray Advanced Material:
        • Disabled layer parameters are not converted.
        • The following layers are ingored:
          • Material weight
          • Diffuse layer 2
          • Specular layer 2
          • Specular layer 3
          • Specular layer 4
          • Specular layer 5
          • SSS layer
        • Transparency texture is used for opacity.
        • Take overrides and animation keys on the layer enabling checkbox will not be converted.
        • Highlight glossiness is ignored.
    • Shaders:
      • V-Ray LayeredMax shader texture is mirrored horizontally after conversion.
      • V-Ray AdvBitmap:
        • Converted to regular Bitmap.
        • Gain is ignored.
        • Animation settings are ignored.
        • Nearest filtering is converted to MIP.
    • Lights:
      • Rectangle light texture is mirrored horizontally after conversion.
      • Portal lights are removed.
      • Parallel light beam radius is considered 0 (the parallel light is converted to infinite non-physical light).
      • Spot Light penumbra angle is recalculated to preserve results.
      • Sun Light:
        • Sky is not converted.
        • Only physical camera intensity multiplier is considered.
    • Tags:
      • Physical Camera:
        • Exposure fixed step increments are ignored.
    • Other:
      • Cinema 4D Layers are not converted.
    Missing conversion:
    • Render elements are not converted.
    • Most shaders are not converted. Only Layered and V-Ray AdvBitmap are converted.
    • Only physical camera tag is converted.
    • Focus Distance inside the physical camera tag needs to be transferred manually from the main camera
    Ivan Shaykov
    chaos.com
    Are you planning on conversion from the old vray materials to the new ones?
    Add Your Light LogoCheck out my tutorials, assets, free samples and weekly newsletter:
    www.AddYourLight.com
    Always looking to learn, become better and serve better.
      Both V-Ray Advanced and V-Ray Standard materials from 3.7 are converted to V-Ray material from V-Ray 5 on scene open, and you should be the same with differences. If they're not looking the same then probably they have a texture or a shader that isn't fully supported yet.
      Ivan Shaykov
      chaos.com
        I'll check again tomorrow but my vray standard materials weren't converted upon opening. There is no button to try to convert them again, is there?
          Once you open a legacy scene (from V-Ray 3.7) you will be prompted with a dialog and you will be asked what action to take. You can either convert the whole scene (materials, lights, textures, settings etc) or you can leave it as it is. There is no dedicated option for conversion it is all done automatically based on the choice you made when the scene was opened. The opened scene is then renamed so you can preserve the original in case you still want to use it with V-Ray 3.7.
          Click image for larger version  Name:	scene_conversion.png Views:	0 Size:	6.6 KB ID:	1085921
          Ivan Shaykov
          chaos.com
            Is there a know issue with textures not being read, if they are located in a different folder (I have specified the path in the preferences)?
            I have tested several old 3.6 files which had 3D people assets where the textures were located in a different folder, but they don't show up. It seems that these textures are not converted, although they should have been either a vray advanced, or standard material.
              Yeah, I did that but some materials were not converted. Will check again tomorrow and if so will send a scene if it helps.
                My bad, these were corona materials. Would be great if these were converted in the future too
                  And it would be great if conersion for c4d standard and physical shaders will be added.
                    Would it be possible to add an external converter, or a converter built into the vray tools available from the c4d level?
                    I have over 4250 scenes, c4d files built from varay 3.7, and I don't like having to manually open each scene separately to convert it to vray 5. It will take me a long time.
                    Would it be possible to convert multiple sceans at once? For example pointing to the directory on disk containing these scenes?
                      hey guys
                      i've being test the converter to try to convert all my library...(a lot of objects i must say)
                      There are some things that are not working as i expect... for example if we have some vray shaders, some of them wont convert, neither let us know the possibility to know which texture were used... i'm aware that probably a automatic process wont do the right thing, but at least we should have the possibility to push all the used textures on the 3.7 version... do you think it's possible?
                      i can make a small video ...
                      thanks and all the best
                      nuno
                        Is there somewhere a good tutorial available about the render setting in 5 (interior)?
                        i imported previous files from 3.7 into version 5 but the previous setting are not wel imported/wrong... I need similar good settings but i dont know how...
                          You don't need to change anything in render settings, just select the correct threshold for the AA or leave the progressive sampler to run until you are satisfied (don't forget to activate the denoiser).
                          Forget about the 3.7, rebuild from scratch all the assets and light setup is your best option.
                          If you are interested on our channel we have several tutorials about Vray 5: https://www.youtube.com/c/3DRenderandBeyond/videos we have made also a few blogposts: https://www.3dtutorialandbeyond.com/blog/
                          3D Scenes, Shaders and Courses for V-ray and Corona
                          NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
                          @3drenderandbeyond on social media @3DRnB Twitter
                            Known issues and limitations[LIST][*]Render Settings:
                            Is the min shading rate option deleted permanently, or it should be available soon?
                            www.rwvision.com.pl
                            • #15
                              Originally posted by RwVision View Post
                              It is hidden permanently.
                              Ivan Shaykov
                              chaos.com
