object ID
  • object ID
    Trying to render out an animation with a mask for an object. But the object ID channel is dark red and with very rough edges. Before it use to be black n white and with a button "consider for antialising".
    Can I get it black n white and as smooth edges as the main render of the object?
    Hi michael_olssson , you need to use the Object Select for that. Just as before, setup an ID and you will have an object (or a group of objects) on a black and white matte.
      YunalZobu Thanks! Perfect! But now I got 4 different channels. Is there any way to just get the one B&W? I want to save out just that channel in a sequence.
      I'm doing an animation. So what I want is one folder with a png of the render. And one folder with a B&W png of the object-selction. So I can use it as an alpha in AE later.
        Now there's 3 other layers that I don't want.
