History
  • History
    how do activate the history in VFB?
    Go to Vray VFB>options>VFB settings>history, choose enable and set a custom history folder, then choose save and close.
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
      We will make this option to be ON by default in the future.
      Ivan Shaykov
      chaos.com
        Dankeschön!
          Hi there If I have activated a Stage with many images render and the history in the VFB does it only save the last image in the history folder? I thought that it works like in Cinema 4D Image Manager and you can select and edit the rendered objects and then save them all at once in a folder ? Thank you very much
            Hi there!
            Maybe someone can help me? I have the problem when I activate the history in the VFB, it does not save the renderings for me (auto save is activated). I have a stage rendering with individual images and would like to edit them in the VFB light mixer etc. Can someone please send a screen shoot for the correct settings!
            Thanks that would be nice
              Originally posted by Wohnraumdesign View Post
              Hi there!
              If you haven't set a path where the files are going to be saved please do so and make sure that you have full read and write rights to it. I tested this on my end, and it seems to be working fine. Can you please check the console and see if there isn't something in the V-Ray log that could be helpful to identify the issue?
              Ivan Shaykov
              chaos.com
                The V-Ray frame buffer doesn't work like the Picture Viewer and doesn't save every frame in the history when rendering animations since the VFB doesn't have a timeline itself. That is why only the last frame is saved.
                Ivan Shaykov
                chaos.com
                  But it would be great if he would save every frame then you could edit the pictures with Light Mixer etc. which would be very useful! Is there another way how you can render multiple frames with light mixer etc. and then reopen them to edit the light sources?
                    Unfortunately the Cinema 4D Stage object is considered an animation, and therefore it won't work with the VFB as you would like to.
                    A better approach and workflow for this would be to use the Cinema 4D "Take" system instead the Stage object. However, we don't have a button to render all or selected Takes within the VFB like Cinema 4D has with the PictureViewer, so this is a good opportunity to add a feature request about this.
                    As a workaround for now you can render and output your files as vrimg files and then load them in the VFB and do the desired corrections.
                    1. Set the output format and folder
                    2. After you have all frames saved Load them inside the VFB do the necessary corrections and save.
                    Ivan Shaykov
                    chaos.com
                      Dankeschön!
                        It would be great if you could load several Vrimg pictures and see them in the history, including saving several pictures.
                        So now it is very tedious to load and save each picture individually.
                          We will try to do something about this when we implement the "Render takes" option for the VFB. That way it will auto save the frame of every camera to the history and you will be able to use it as you suggest above.
                          Ivan Shaykov
                          chaos.com
                            Just do exactly how the picture viewer is working and you're home. And also a way to save .psd files with the channels in it.
                            • #15
                              I agree with this, however as much as we want to make it like the picture viewer sometimes a frame from the VFB could take quite a lot of space (up to 700 MB and more if you include the render elements just for the beauty pass) and having all of those in a timeline like the Picture Viewer has we will end up without RAM in no time.
                              We have this as a request already, and it will take some time to research this and how it could be done properly.
                              Ivan Shaykov
                              chaos.com
